You have the limited slip rear. Rebuild kits are fairly inexpensive, and you can do it without pulling the carrier.
Not to threadjack, but my google-fu is apparently lacking. HeyYou, do you have a link or a DIY for replacing the limited slip clutch pack without removing the carrier? I’ve put mine off for a long time because I just couldn’t stomach pulling it out of the axle.
Look up Chris fix on YouTube he has an am excellent video is doing just that. It's on a Ford but it exactly the same on ito Dodges.
