Engine turns but won't start after I swapped out transmission
Old Apr 22, 2018 | 12:40 PM
Bradly b's Avatar
Bradly b
Default Engine turns but won't start after I swapped out transmission
I just swapped out the transmission on my 2000 Dodge Ram with 5.2 l swap the ignition also key turns starter rolls over it's getting gas it won't crank can somebody help me
Old Apr 22, 2018 | 01:03 PM
I bet you destroyed the crank sensor doing the trans R&R.
Old Apr 22, 2018 | 10:19 PM
Bradly b's Avatar
Bradly b
I don't think I did. I took it out before I pulled the tranny from the motor. it was in one piece. I was reading something about the air gap and a paper gasket? If I did destroy it will that cause me to not get my plugs to fire?
Old Apr 22, 2018 | 10:21 PM
Bradly b's Avatar
Bradly b
and when you said I would need the electronics where you talkin about the shift solenoids inside the pan or were you talking about the sensors outside on the transmission
Old Apr 23, 2018 | 08:14 AM
I would take a look at the crank sensor, and verify that it is still in one piece. No gasket for it that I am aware of. If the sensor is damaged, the truck most certainly will not run.
Old Apr 26, 2018 | 08:26 PM
Bradly b's Avatar
Bradly b
it was crank sensor . Thanks
Old Apr 26, 2018 | 10:11 PM
true blue's Avatar
true blue
I noticed you said, " l swap the ignition also". Are you saying you replaced the distributor ***'y?
