Steering gears?
Borgeson has worked well for me. While not a big deal, please note that the Borgeson steering box moves the centerline of the pitman arm about 1/2" further out away from the frame, since the steering box is thicker in the mounting area than the stock steering gearbox. If you are running a frame mounted steering stabilizer with a bearing that ties in the steering box output shaft, you must have one that works with the Borgeson steering box.
