Overdrive thunking
Old Apr 23, 2018 | 10:13 PM
cjames1173's Avatar
cjames1173
Default Overdrive thunking
In my 2000 RAM 1500 w/ 5.2 318 V8 2WD, I've got a random yet repetitious 'thunk' (almost like a misfire) from as soon as I hit OD until my rpms are 1800 or higher. already replaced U-Joints and corrected thunk from stop. ANy Idea's? This problem has rapidly gotten worse over the last 10 Days
Old Apr 24, 2018 | 07:55 AM
May it IS a misfire....... When's the last time your plugs/wires/cap/rotor where changed? Checked the plenum yet?
Old Apr 24, 2018 | 10:03 AM
cjames1173's Avatar
cjames1173
Default Thunking in OD
I changed the plugs/cap/wires/rotor roughly 40k miles ago. Also did thorough throttle body cleaning and IAC replacement. Did smoke test over open oil fill home and no vacuum is present. Thanks
Old Apr 24, 2018 | 02:54 PM
What plugs? 40K miles, it's likely time for new ones.... (along with cap/rotor.)
Old Apr 24, 2018 | 02:58 PM
cjames1173's Avatar
cjames1173
You're totally right, they were the standard champion copper plugs and they were worn to .055 gap, I personally gapped them to .040 on install last year, just couldn't believe they went bad so fast (it seemed). New plugs wires etc fixed my problem, thank you!!
Old Apr 24, 2018 | 02:59 PM
Gotta love the easy ones.
