Com flash
Old Apr 26, 2018 | 08:30 PM
Bradly b's Avatar
Bradly b
Default Com flash
Any body in or near Memphis that can help me flash these PCMS for my trucks cheap?
Old Apr 27, 2018 | 07:37 AM
Flash it for what?
Old May 3, 2018 | 01:03 PM
Bradly b's Avatar
Bradly b
Flash it for what?
I have a couple different PC m I put one on the truck and none of the gauges work I put the other one on the truck all the gauges work then I have another one I can put on the truck all the gauges work but it's stuck in tow mode these are all on the same truck and I was told that I need to have pcm flashed
Old May 3, 2018 | 01:59 PM
AtomicDog's Avatar
AtomicDog
For what you need to have done, its likely a dealer PCM flash, unless someone procured the equipment from a dealership to perform the flash and knows how to do it. Still seems that self-flashing our JTEC PCMs are out of reach for the masses.
Old May 3, 2018 | 02:50 PM
Bradly b's Avatar
Bradly b
I was told that if I get a j2534 pass through device and a subscription to the Mopar website I should be able to flash it myself is that true or false
Old May 3, 2018 | 03:31 PM
AtomicDog's Avatar
AtomicDog
I checked into that some time ago and at the time, there was a substantial cost to obtain the subscription.
Old May 3, 2018 | 04:06 PM
The 2000 trucks will need the PCM flashed to the correct VIN. Otherwise, things like ABS, and SRS get offended. If you are seeing other issues, I highly doubt a simple flash is going to change anything.
