No start and stall after governor pressure sensor and solenoid replacement
Old May 1, 2018 | 08:52 AM
Mark Woolf's Avatar
Mark Woolf
Default No start and stall after governor pressure sensor and solenoid replacement
This is a weird one, I recently replaced my governor pressure sensor and solenoid as well as a transmission filter. When I first started it up it ran then stallee immediately. Then wouldn’t start at all, I let it sit for a second and she started up. Is this normal operation? My tranny also was making a winning noise, but I think that was because the fluid was not at the correct level yet. It all seems to be running fine now.
Old May 1, 2018 | 05:06 PM
Not really normal...... not sure what would cause it though..... If it's running fine now though, I wouldn't worry about it.
Old May 8, 2018 | 05:40 PM
Mark Woolf's Avatar
Mark Woolf
P1757 code came back after replacing the governor sensor and solinoid as well as a filter. Truck is real sluggish off the line. Not sure why it came back other then something getting stuck in the sensors. Any ideas?
Old May 8, 2018 | 07:22 PM
Its saying governor pressure is above 3 psi, when the truck isn't moving.... so, the input voltage may be high, (short in the wiring) might be a bad sensor/solenoid, or bad valve body...... or even bad pcm. Plug in with a scanner, and see what the PCM thinks is going on.
