No code just won’t start
Old May 4, 2018 | 01:34 PM
Wardallj's Avatar
Wardallj
Default No code just won’t start
fuel pump is fine, getting around 50 psi at the fuel rail. All injectors are good, spark side is brand new from coil to plugs. Have replaced the cam and crankshaft sensors. It originally **** a p0201 code. Now it won’t put any code out. To me it seems it’s not getting fuel, by itself it won’t fire over, but with some gas down the intake it fires but then dies out like it’s being starved. Someone said something about some anti theft system that’s in these that will activate for whatever reason. Anyone have any ideas? Oh also my timing is right where it needs to be
Old May 4, 2018 | 03:58 PM
Michael92's Avatar
Michael92
I would start by renting a noid light and making sure the injectors are getting power, doesn't mean there actually working though. I know there's an automatic shutdown relay in our trucks that'll knock power to coil and injectors also. Maybe check out that relay or switch it with another in the fuse block, it's under the hood. Marked asd I believe. Other then that just verify your getting spark and that your injectors are firing. Fuel, spark and air is all you need.
Old May 4, 2018 | 04:00 PM
Michael92's Avatar
Michael92
And from looking up your code, #1 injector problem, says it may have gone into fail safe mode.
Old May 4, 2018 | 04:01 PM
Yep, check and see if you are getting injector pulse.
