1998 2500 fogs do not work with low beams on.
Old May 18, 2018 | 02:31 PM
V10Burnouts's Avatar
V10Burnouts
Thanks. Can't work on it at it at the moment but will when I can soon.
Old May 19, 2018 | 12:31 AM
Sheriff420's Avatar
Sheriff420
I have a jumper wire in place of my fog light relay so they're on all the time when I pull the headlight switch out. I though it was dumb that you couldn't run the fogs with the high beams since you only run the high beams when no one else is around. The same reasoning is why my off road lights in the bumper are wired into the high beams and whenever I finally get a light bar it'll be hooked into the high beams as well.
