Re-ring
Old May 27, 2018 | 02:23 PM
I don't know what the difference is, but, there evidently IS a difference...... so, stick with the stuff that is specifically for your motor. If you can't find it in the catalogue, CALL them, and talk to a live human being.
Old May 27, 2018 | 07:03 PM
Cweldy's Avatar
Cweldy
It's not making any strange noises and has decent oil pressure. Just gonna order standard sized stuff.
Old May 29, 2018 | 01:34 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Yeah, fleet vehicles.... Was that something dodge did? Or was it an aftermarket add-on?
Originally Posted by Cweldy
I know what it's for. But what's the difference in them ?
Sorry for the late reply trying to figure out my own electrical problems. Yes it was factory and this is a big difference as they had higher compression so you got thicker rings.
Old Jun 3, 2018 | 01:28 PM
Cweldy's Avatar
Cweldy
I just pulled the heads off. The cylinder with the lowest compression has a blown head gasket. Putting oil in the cylinder wouldn't raise the compression if the head gasket was the only problem would it ?
Old Jun 3, 2018 | 02:25 PM
Nope. oil in the cylinder only brings up pressure if rings are the ONLY problem. If the cylinder walls look good, you might be ok. Could put a bore gauge on it, and check for taper/out of round. Can probably rent one at the local parts store.
Old Jun 3, 2018 | 03:41 PM
Cweldy's Avatar
Cweldy
Cylinder walls look good. The stock ring was at like .05 gap so I'm assuming that's my issue. New one is .018 out of the box.
Old Jun 4, 2018 | 07:55 AM
What is spec for ring gap with new rings???
Old Jun 4, 2018 | 08:20 AM
Cweldy's Avatar
Cweldy
Old Jun 4, 2018 | 08:21 AM
Ah.
Old Jun 4, 2018 | 08:22 AM
Cweldy's Avatar
Cweldy
Anyone know what this is? Not sure but I think it came out of the engine
