Cruise control not setting
Old Jun 13, 2018 | 10:55 PM
rjp1965's Avatar
rjp1965
Default Cruise control not setting
Hoping someone can help me narrow down a problem. I have a 1998 Ram 1500 with the 5.9L / 360ci engine. My cruise control won't set. I get the green light indicator on the instrument panel when I turn cruise on, but it will not set when I push the set button.
I thought the problem was likely the clock spring because my horn also didn't work. I have replaced the clock spring, but the cruise still will not set.
Any information or advice as to what the issue might be would be greatly appreciated. Thanks.
Old Jun 14, 2018 | 12:01 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
It's the switch most likely
Old Jun 14, 2018 | 11:53 PM
rjp1965's Avatar
rjp1965
Thanks. I'll look at replacing it.
Old Jun 15, 2018 | 02:18 AM
MoparFanatic21
<br />Download your FSM from the FAQ section it has a test to test the switch before replacing it.
Old Jun 16, 2018 | 02:19 AM
rjp1965's Avatar
rjp1965
Thank you. I wasn't aware of the FSM availability. I appreciate it.
Old Jun 16, 2018 | 02:41 AM
MoparFanatic21
No problem! Hopefully you find out what it is!
