what are the symptoms of a failed 72472 m transmission relay
Old Jun 14, 2018 | 03:27 AM
sporty14's Avatar
sporty14
Default what are the symptoms of a failed 72472 m transmission relay
2001 dodge 1500 sport 4 wheel drive all gears work but when you stop then try to back up wont back up you can hear it go into gear but it feels like its trying to go forward changes lock and overdrive solenoid and presuur solenoid filter new plus 4 fluid reae seed sensor but it does the same thing if you put it in neutral cant push backwards
Old Jun 14, 2018 | 07:53 AM
Internal failure, time for a rebuild.
