Heater core bypass help
Old Jun 25, 2018 | 07:06 PM
Green95v10's Avatar
Green95v10
Default Heater core bypass help
I havent been able to find barely anyone else trying to bypass their heater core, if at all with the magnum v10. Im currently up on a job a state away from home for the week and was wondering if anyone had any ideas of how to get a temporary fix for bypassing, i have no way of accesing where the hoses connect to the heater core at the firewall because of the throttle body blocking any access.
Dont have the means or the time until i get home to do a legitimate bypass where the hoses run through the firewall here
Is there anyway i can undo the 2 clamps here and run a temporary bypass untill i can get home on Thursday or Friday
Old Jun 25, 2018 | 07:11 PM
Pair of pliers to squeeze the clamps, pull the hoses apart on the heater core side of the joint, then, run a hose from one to the other, and just put the long hoses going back to the heater core out of the way somewhere they won't get munched up, or burnt.....
Welcome to DF! Check out the second gen ram section.
Old Jun 25, 2018 | 07:17 PM
Green95v10's Avatar
Green95v10
i figured, just wanted yo make sure it was doable from there without any specific things to do differently. Thanks hey you, really appreciate it
