Miss At Idle / Exhaust Suck
Old Jul 12, 2018 | 10:40 PM
racefan41's Avatar
racefan41
You said you tested for for spark, did you spray/mist some water on the wires and boots to see if you had any arching going on?
Old Jul 13, 2018 | 10:10 AM
99DR's Avatar
99DR
no need. As I stated, the compression in cylinder #6 is 50 psi. No need to check anything else. That is the issue. I’ll do a leakdown test tonight and see exactly where the pressure is leaking...but I suspect a bad exhaust valve.
Old Jul 13, 2018 | 04:53 PM
racefan41's Avatar
racefan41
I noticed after I posted that, that your issue was found. I should have read through a little better.
Old Jul 14, 2018 | 04:37 PM
99DR's Avatar
99DR
Have the heads checked for cracks. Either that, or just replace them with some NEW, aftermarket, better castings.
OK, so I got the diagnosis completed.
Compression (wet)
1: 150
2: 160
3: 155
4: 150
5: 160
6: 60
7: 150
8: 160
I did the leak down test and it became apparent very quickly what the issue is. A fairly loud whoosh was coming from the tailpipe. I have to wonder if they could have made it a little more difficult to remove that rear inner stud on the valve cover! It appears to have been made for a Hobbit with 5 micro universal joints! Anyway, time to order a new head. The plenum looks clean, but I might as well add the Hughes fix while I have it torn down.
Old Jul 14, 2018 | 05:47 PM
Replace both heads. You'll be happier.
