will trans from 98 durango with 5.9 and 4x4 work in 97 5.9 2wd?
Old Jul 10, 2018 | 06:27 PM
Anthony Putnam's Avatar
Anthony Putnam
Default will trans from 98 durango with 5.9 and 4x4 work in 97 5.9 2wd?
Old Jul 10, 2018 | 06:45 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Yes you will need your tail housing from your transmission and some electrical connectors might have changed inside the trans (this will only affect if you buy parts for inside the trans)
Old Jul 10, 2018 | 07:18 PM
Is the tailshaft the same from 2 to 4wd? I think there is a length problem there. In any event, you would be better off finding a correct trans.
Old Jul 10, 2018 | 10:55 PM
MoparFanatic21
His will work as a 4wd is just a tranny with a transfer case and short tail housing. Is he uses the one off his tranny it will work
