Heater core
Could anyone tell me how to tell if your heater core is clogged? My heater barely heats at all. I thought maybe it was the thermostat, but someone said if that was the case then i would not get any heat at all. I do get some heat, but not very hot. Thanks for your help.
Not sure on how to tell about the heater core unless you pull the hoses off the heater core and try to flush water through it, if it runs freely then not clogged, you need to do this in a back flush way, backwards of how the water normally flows, that way if it has something clogging it, should push it back out.
As for thermastat, you can still get a bit of heat even it it is bad(mine did) it was stuck open(actually almost fell apart), so it was slowing the water enough to give a bit of heat, but not doing what it should.
I would go ahead and change it anyway, for some reason, people over look the thermostat way more then they should. It should be changed at least every 2 years. Good luck
