Superchips, Pinging, and Bad Shifting. Thoughts?
Old Aug 9, 2018 | 09:58 AM
jlake4130's Avatar
jlake4130
The shuttle shifts from 2nd, 3rd, 2nd, 3rd is a dead give away. The "shuttle shift" you are experiencing is a common issue, I remember reading a thread about it and how to correct it. Maybe someone else can chime in with more info. If not google "ram 46re shuttle shift".
Old Aug 10, 2018 | 10:33 AM
Skeptic68W's Avatar
Skeptic68W
If your truck is 96 and up, you shouldn't even HAVE an EGR valve.....
Ran any combustion chamber cleaner thru it? Carbon deposits can induce ping. They create hotspots that will ignite the mixture prematurely.
Haha good point. I was thinking of the PCV valve.
Cylinders are clean. I seafoam a few times a year and when I was in the motor less than a year ago, I cleaned out all carbon from the combustion chamber.
I put in the new ignition parts this morning. Not many places where I can go WOT on my way to work (live in a city), but I got a short run in on one stretch and I think that might have solved my pinging issue. The cap had some corrosion and 2 wires had been burned pretty severely on a header.
Old Aug 10, 2018 | 10:35 AM
Skeptic68W's Avatar
Skeptic68W
I did a quick search for that, and will do some more digging. My trans is a reman unit that's about 2 years old that I installed a Transgo TFOD JR shift kit in. Shifts perfect when not tuned, but with the superchips tuning it does the "shuttle shift".
