Abs light
Old Aug 7, 2018 | 09:09 PM
95betsy90's Avatar
95betsy90
Default Abs light
I have a beloved 95 1500 that was stolen from me about a year ago. Got it back not long after. Missing a lot of course. In the process of getting it back on the road. It's been sitting for about 8 months, other than starting it and moving it a small amount every once in a while, and the abs light is on and the pedal goes to the floor. Fluid is full. Where should I look for a fix?
Old Aug 7, 2018 | 09:35 PM
fj5gtx's Avatar
fj5gtx
Not sure why the abs light is on, perhaps just a sensor. But if you're not building pressure and also not losing fluid, you likely have an internal leak in the master cylinder.
Old Aug 16, 2018 | 12:08 PM
crazzywolfie's Avatar
crazzywolfie
did you do any brake work to it since you got it back? if the pedal is going to the floor you generally have a leak or there is air in the system. it would probably be best to re bleed the brakes and see if that helps.
Old Aug 16, 2018 | 08:20 PM
Moparite's Avatar
Moparite
Sounds like you have a broken line. Keep pumping the pedal and see if you see fluid on the ground. The line next to the gas tank has a history of rusting out and bursting. It will set off the abs light.
