Instrument Cluster Working Intermittently
Old Aug 9, 2018 | 01:23 PM
Burgundy98RAMMER's Avatar
Burgundy98RAMMER
Exclamation Instrument Cluster Working Intermittently
Hey guys, got an issue that I can't figure out and need a bit of help. My instrument panel works, everything except the oil pressure gauge, which I think is the sender switch connected to the firewall (i'll be replacing that this weekend). Anyways, the panel and almost all the indicator bulbs light up, I think I have a couple burned out. The issue is, while I'm driving at various speeds, the instrument panel will just stop working. When I say stops working, I mean the tach, speedo, and all gauges will drop down to zero. After a couple more seconds, the airbag indicator will come on, as will the low-fuel indicator and dinging will sound that accompanies it normally. Now, sometimes it take a smack on the front of the panel to get it back to working, other times if I just give it a minute, it will start working again.
Any suggestions?? Ground? Connections behind the cluster?
I haven't taken the cluster off yet because I wanted to check the grounds first, but I don't know where they're at, could someone help with that?
Thanks so much everyone!
Old Aug 9, 2018 | 02:00 PM
Please provide your vehicle details so everyone knows what you are working on.
