Valve bolts Location
Old Aug 15, 2018 | 03:57 PM
BigTunaDaBoss's Avatar
BigTunaDaBoss
Default Valve bolts Location
Can any get a picture of their valve cover bolts? I took them out but didn't label where the longer ones go and the shorter ones go. I know the middle on the outside has the metal cylinder around it but not sure about the rest.
Am doing Stem Seals and there is quite a lot of sludge in the head. Doing the air compressor way so the valves don't drop.
Old Aug 15, 2018 | 06:24 PM
Moparite's Avatar
Moparite
The longer ones are for the wire looms if you still have them.
Old Aug 15, 2018 | 07:06 PM
Jaw91097's Avatar
Jaw91097
All four corners and the middle bolts on each side of the valve cover are longer
