track bar ... upgrade to 3rd gen?
Old Nov 3, 2018 | 05:48 PM
  #91
Really? But dude when I crawl at the mall I need the most flex bro
Don't tighten the bolts all the way.
Old Nov 3, 2018 | 06:50 PM
  #92
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I'll have to try that on my control arms
Old Nov 3, 2018 | 10:23 PM
  #93
AtomicDog's Avatar
AtomicDog
I don't know who to go with. There are many variations of the bracket I don't know which one is the strongest. Then comes the track bar. I need an adjustable one but do I want heim joints or regular bushings
Solid Steel makes an adjustable 3rd gen style track bar with poly bushings on each end. Its an excellent, well made bar and I run it with no issues at all. I'm not a fan of heim joints for regular use.
Old Nov 3, 2018 | 11:38 PM
  #94
fj5gtx's Avatar
fj5gtx
There is a used setup on ebay right now.... that bracket looks a little familiar. Although one end of the bar looks adjustable...
https://www.ebay.com/itm/264022160783
Old Nov 3, 2018 | 11:43 PM
  #95
fj5gtx's Avatar
fj5gtx
I wish I could have tried it on my truck. I searched and found no one with your problem. Even the eBay Chinesium 3rd gen conversion mounts worked on people's truck.
You could just order one and give it a try, then I could try yours !
I'm tempted to go back to the jyard with my battery reciprocating saw and take the 3rd gen bracket and part of the frame. The real trick is, how to get a homemade bracket it in the right position on the frame to make sure the axle is in the right place.... that, and enough free time to mess with something optional like that, is what is stopping me.
Old Nov 4, 2018 | 01:45 AM
  #96
MoparFanatic21
Well lit is technically a street legal rock crawler
i just ordered the bracket and the kit on eBay
Old Nov 4, 2018 | 09:04 AM
  #97
That one has a heim joint at the axle end, and a bushing on the frame side. Compromise between rigidity, and ride quality. (joints tend to transmit EVERY shock and wiggle to the frame.) Be interesting to see how long the joint lasts. I do believe they are at least rebuildable.
Old Nov 4, 2018 | 11:03 AM
  #98
MoparFanatic21
I didn't go with that exact kit had to get one adjustable for 6-8" lift so I didn't have to buy a drop bracket
Old Nov 4, 2018 | 11:19 AM
  #99
Don't forget the drop pitman arm as well.
Old Nov 4, 2018 | 04:05 PM
  #100
MoparFanatic21
Already got that with the lift kit now she needs to be higher know anyone who sells 9in coil springs
