Wont hold idle, between idle and 1900 rpms,out of gear
Old Aug 30, 2018 | 07:10 PM
  #21
Resetting the PCM makes it forget how it ran the engine previously, so any 'bad' learned habits go away.
Yep, those are correct readings.
Use a MOPAR IAC, the aftermarket fellers just don't seem to work as well.
Old Aug 30, 2018 | 07:13 PM
  #22
Michael92's Avatar
Michael92
Mopar iac is expensive as downright dog crap. The one i got a year or so ago is a cheap wells off ebay. Between the iac and a new throttle cable, hopefully one of the two fix it. Just wondering what a normal 318 or 360 does at a cold start. RPM wise. Mines never been rite so idk how high or long they usually hold rpms before it starts to idle regularly.
Old Aug 30, 2018 | 07:15 PM
  #23
At startup, it should flare to around 1500, then settle back down to 650-800. (lower RPM the warmer the engine is.)
Old Aug 30, 2018 | 07:21 PM
  #24
Michael92's Avatar
Michael92
Is that drop in rpm almost instantly, slowly, or very slowly ?
Old Aug 30, 2018 | 08:25 PM
  #25
It should settle down to idle speed in less than a minute.
Old Aug 30, 2018 | 08:31 PM
  #26
Michael92's Avatar
Michael92
Thank you for all the help!!
