wheel help
Old Sep 3, 2018 | 12:38 AM
enrique 300's Avatar
enrique 300
Default wheel help
hi my name is enrique i own a dodge ram 2001 single cab fully stock and i also have a 2018 daytona 392..... i need help on my truck i wanna put some srt10 22 inch wheels or some 20 in newer stock wheels from a newer ram truck i wanna know if they will bolt right on or i will need to make some adjustments please help me again the suspenions is fully stock thank you
Old Sep 3, 2018 | 08:37 AM
Welcome to DF!
If your truck is a 4x4, it's a direct swap. If your truck is 2wd. The wheels need to have the hub centers opened up to fit the larger hubs. (or, turn the hubs down, so the wheels will fit.)
Old Sep 3, 2018 | 11:17 AM
enrique 300
Default Wheel help part 2
Welcome to DF!
hey thanks for the info .. yea my truck is a 2wd so the front will fit and the back need to do some adjustments? Sorry I’m new at this so I got a lot of questions and how wide a rim can I run on it ?
Old Sep 3, 2018 | 11:19 AM
I think the rears will fit, but, the front will need some modification.
How wide? Depends on what size (diameter) tires you want to run, and backspacing. Start getting too wide, and the tires will rub various things.
