Grinding Noise
"Grinding or "Impact wrench" sound that gets louder with engine load - Transfer case output shaft snap ring broken allows shaft assembly to move backward and grind into the case"
IS DIS IT?
[IMG]local://upfiles/16276/C21458B4C37F478BAEBF377AA447741F.jpg[/IMG]
IS DIS IT?
Great pic and diagram....That looks like the snap ring "huttbutt" was refering to.
That would be great if that was my problem....if that is my problem would the grinding noise go away when 4wd was engaged?
did it sound like the noise was comming from the rear end? I am having the same problem and someone told me it is the rear differential. The noise goes away if I let off the gas and then repress the gas. It is a terrible grinding noise that is really bad.
