AC blows out of defrost only
Old Sep 5, 2018 | 11:47 PM
Johnny Almeida's Avatar
Johnny Almeida
Default AC blows out of defrost only
I was wiring a new speaker to driver door and during process had to turn key on several times for testing. It appears the blend door stopped engaging cause i normally hear the door engage when i turn vehicle on. Once done with the speaker i noticed AC was blowing cold out the top only and not out of front vents no matter what i did with controls. I had the blend door replaced some 8 years ago. Would it be safe to say it went out again? or perhaps that one small plastic piece that is known to crack?? This is for a 2001.
Old Sep 6, 2018 | 01:02 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Could be a vacuum issue there is a thread stickied at the top called "Wild Vents"
Old Sep 6, 2018 | 02:27 AM
Johnny Almeida
you're right, will check the vacuum hoses and check valves. i've had the wild vent issue before.
Old Sep 6, 2018 | 09:33 AM
Johnny Almeida
sure enough, just like last time, one of the two vacuum lines that go into the cab was disconnected. all is good.
Old Sep 6, 2018 | 12:44 PM
MoparFanatic21
Glad you got it fixed! Sometimes it is that simple!
