1999 ram 1500 5.9l 4x4 light on
Old Sep 10, 2018 | 06:51 AM
crzmn1's Avatar
crzmn1
Default 1999 ram 1500 5.9l 4x4 light on
The previous owner replaced the transfer case and the 4x4 light stays on all the time regardless of the shifter position. Any ideas.
Old Sep 10, 2018 | 07:12 AM
Is it in 4x4 all the time?
Old Sep 10, 2018 | 07:15 AM
crzmn1's Avatar
crzmn1
No it goes into 2wd but the light stays on
Old Sep 10, 2018 | 07:37 AM
Check and see if vacuum changes at the CAD on the front axle when you shift from 2wd, to 4wd. May be a bad switch, (either at the t-case, or on the cad) bad cad.... Need to look and see.
Old Sep 10, 2018 | 08:01 AM
crzmn1's Avatar
crzmn1
I know the cad pot is loose you can wiggle it around would that affect the indicator switch
Old Sep 10, 2018 | 08:16 AM
The shaft from the pot pushes in on the switch to turn it on, so, I would think you would see the opposite problem if that were it...... Might be as simple as a bad switch. Easy enough to take it out, and test it.
Old Sep 10, 2018 | 05:41 PM
fj5gtx's Avatar
fj5gtx
Like HeyYou said, check the switch. But I do not think you should be able to wiggle it around, how much wiggle and which direction? I'd pull it apart and see what is going on. I put a new vacuum motor in mine for about 70, but I ended up having to drill out my housing to accomodate the far end of the shaft.. dang poor quality aftermarket with a slightly thicker than factory spec rod. But it works great now, and I made sure I hit it liberally with cavity wax to keep the corrosion to a minimum.
