Two bolts on bellhousing where heliocoiled , now what ?
Old Sep 27, 2018 | 07:25 PM
POSram2001's Avatar
POSram2001
Default Two bolts on bellhousing where heliocoiled , now what ?
Finally got that rebuilt tranny in there. What a ****, anyway two of the bolts wouldn’t go in because who ever had it before must have stripped or broke them off and had them heliocoiled.
the bolts wouldn’t go in and we where confused as to why but we saw it when we shined a flashlight on the holes.
I have a buddy who has a tapping kit and he said he’ll come by and tap them for me ( only put the tranny up, left everything else off for time being) so what I’m asking is even if we tap those two bolts in there will this tranny come off when I’m driving ?
im paranoid and scared. Especially if I engage 4x4
Old Sep 27, 2018 | 10:13 PM
AtomicDog's Avatar
AtomicDog
You mean there are two heli-coils in the back of the engine block for a couple of the transmission bellhousing bolts? If so, there is nothing wrong with that as long as the bolts can screw into the heli-coils. As long as the heli-coils were properly installed, there is nothing to fear from them. Removing the heli-coils and taping the bolt holes again will require a much larger diameter bolt to have to be used.
Old Sep 27, 2018 | 11:45 PM
Torxhead's Avatar
Torxhead
If the Heli-coils are damaged they can be removed and replaced with new ones. Providing you have the installation tooling that usually comes with the kit they come with. You can pry a coil up with a small screwdriver and pull it all out with a pair of pliers. I would think there is plenty of internet info on the process.
Old Sep 28, 2018 | 02:29 PM
2bit's Avatar
2bit
I agree, pull the heli-coils out if they are damaged, chase the threads with a tap, then install new heli-coils.
