241 dld
Old Oct 1, 2018 | 02:23 PM
Seth2000's Avatar
Seth2000
Default 241 dld
what are the differences between the 1994-1997 241dld and the 1998-2002 241dld
Old Oct 1, 2018 | 04:06 PM
Shift pattern, shifter mounting, no provision for VSS on 98 and up.
Old Oct 1, 2018 | 04:28 PM
Seth2000's Avatar
Seth2000
I swapped the mounting piece will it work in a 2000 5.9
Old Oct 1, 2018 | 04:46 PM
No clue. What year t-case did you get?
Old Oct 1, 2018 | 05:07 PM
Seth2000's Avatar
Seth2000
It’s from a 1996 cummins 12v with a 47re mines a 2000 24v with a 47re
Old Oct 1, 2018 | 08:49 PM
Bolt right in. Shift pattern will be different, and you won't use the VSS on the tailhousing. May have to modify the shift linkage for the t-case, but, not sure on that.
