‘97 dodge 2500 v8 4x4 12v Cummins swap
Old Oct 12, 2018 | 09:37 PM
Gharve88's Avatar
Gharve88
Well I appreciate all the responses, just at a spot where I wonder if I should stroke it or do the 12v Cummins swap. These stock 360’s just seem gutless and just want a little more push when I get on the throttle.
Old Oct 12, 2018 | 09:43 PM
Strokers are expensive....... of course, the cummins swap wouldn't exactly be cheap either.
Could rebuild the 360, better heads, better cam, better intake...... and a tune. Get what ya want, and still cheap and easy to maintain.
Old Oct 13, 2018 | 12:28 AM
Gharve88's Avatar
Gharve88
hahah yes either way there’s some cash involved, just trying to get the best bang for the buck. I tow quite abit and nothing too big. Just a 19’ jet boat. What’s the best way to somewhat compare to the newer hemis?
Old Oct 13, 2018 | 08:53 AM
The newer hemis are significantly more advanced engines. More power from similar size engine. More efficient too..... Of course, with all the bells and whistles, comes more problems...... Nothing new under the sun. Have a read of the third or fourth gen ram sections for an idea of common problems. There aren't really that many.
Old Oct 13, 2018 | 10:46 AM
Gharve88's Avatar
Gharve88
so there’s not really many problems with them is what u are saying? Ya I get they are designed a hell of a lot different these days and they seem to run good too. My brother has one. I guess I’m just trying to compare mine to that wondering how I can come close
Old Oct 13, 2018 | 12:54 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
You can swap a Hemi in these trucks. That would be your most expensive option and the one I am taking next spring.
Old Oct 13, 2018 | 01:20 PM
Gharve88's Avatar
Gharve88
ya I thought about that too. Yes it’s very expensive but I’ve seen there’s a lot to do to make that work
Old Oct 13, 2018 | 03:27 PM
MoparFanatic21
Not really. All you have to do is trim driver's side motor mount on the frame (not necessary but to get the engine to sit 100% level). Then you can but everything else already made (into about $3,250 last time I checked). Oh and a Hemi motor.
Old Oct 13, 2018 | 03:38 PM
Gharve88's Avatar
Gharve88
Is the 3250 including the Hemi?
Old Oct 13, 2018 | 07:30 PM
MoparFanatic21
No there just for the modified engine harness, brand new computer, pedal (which is drive by wire), and a few odds and ends. I got my Hemi for $200 as it had a rod knock. I am rebuilding it to make 650hp naturally
