Alternator?
So I fixed my water pump the other week, and when I went to start the truck it was fine, but the gen light came on every once in awhile then would go away. The battery gauge fluctuated up and down and would sometimes drop below 10, but it usually started anyway.
Well, I let the truck sit for a week because it needs ball joints and it was starting to get really sketchy and all over the road...(I sit in it and listen to music sometimes...and other things, so it’s safe to say I definitely drained the battery a little bit) but when I went to go start it to drive it the other day the battery was dead, so I jumped it with the Honda, and this happened in the video...
i got it it warmed up and then it idled fine afterwards, then I drove it around the block once or twice, charged the battery a little. Then I parked it again for a day or two, went back out to it and it was dead again.
I thought maybe I messed with a connection while doing my water pump, so I went back into it and cleaned off all the connections I thought I touched, tightened one or two bolts a little further down, but same issue.
This is also my third new battery in the last year lol..
With all that being said, would it make sense that my alternator has just gone bad? I can go pick one up for $25 at a pull a part place about ten minutes down the road so I’m not too concerned about the price.
Thank you
i was pressing the gas to make it do that, but about a minute later it idled fine
Thank you
http://alternatorstarterrebuildkits.com/product/dpo/
