96 1500 5.9 4x4
i swapped motor out for a good used one that came out of a 96 2500 4x4 put new crank censor, cam sensor or what ever is under rotor, timing gear and chain and timing marks crank gear dot up and cam gear dot down facing each other the rotor is facing plug wire #1 no start has spark and 45-50 psi fuel pressure? Hope I didn’t ramble to much
