2001 360 cui Ram, the RS exhaust manifold is leaking
Old Nov 26, 2018 | 12:07 PM
jdwal's Avatar
jdwal
Default 2001 360 cui Ram, the RS exhaust manifold is leaking
The bolt heads are gone due to rust, if I just grind them off is there enough clearance to pull the manifold off, then remove the remaining stud? has anyone done this?
Old Nov 26, 2018 | 12:10 PM
On the passenger side, that should be doable. Disconnect from the y-pipe, pull it down out of the way, grind the bolt heads off, and slide the manifold off.
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
You could do that if you have either a torch or can let the truck sit with penetrating fluid for a couple days. You should have at least 1/2" after the manifold is off
Old Nov 28, 2018 | 09:39 AM
87Beast's Avatar
87Beast
When you say "gone" presumably there's still something to grab on to there? I ask because I just did my exhaust manifold gasket on passenger side a couple weeks ago. I was ready for a fight with the bolts. I let the motor warm up and just to see what I was in for I put a socket on the exhaust bolts and started applying some steady pressure. All of the bolts broke loose with only moderate effort. I certainly could have done it with a pair of vice grips if I was desperate. Didn't even disconnect the y pipe, I just slipped the new gasket in place and bam, runs and sounds great.
Give it a shot first before you grind them off...
