2002 Ram 3500 electrical problem
Old Nov 29, 2018 | 04:12 PM
CONSTRUCK's Avatar
CONSTRUCK
Default 2002 Ram 3500 electrical problem
I have a strange problem. When I turn the headlights on, the dash lights and radio display light goes out. Any ideas?
Thanks in advance
Old Nov 29, 2018 | 04:15 PM
Bad ground, or a short somewhere. Check the headlight switch first. The earlier trucks were know for having problems with them. (melted switch and connector....)
Old Nov 29, 2018 | 08:04 PM
Ramman18's Avatar
Ramman18
That issue was supposedly resolved in 99 with the rotary switch. Although if you run low dimmer a long time it gets very hot.
Pull the bezel (carefully) and then the switch is just a couple screws. You'll see all the wires and connections there.
Old Dec 2, 2018 | 07:36 PM
CONSTRUCK's Avatar
CONSTRUCK
Well put me in for idiot of the month award, the problem was the wheel dial for the dome,cargo light was set too low.
Old Dec 3, 2018 | 12:01 PM
Ramman18's Avatar
Ramman18
You're not an idiot, we've all been there! Glad it was nothing to fix.
