2001 1500 Sport 4x4
Old Dec 2, 2018 | 11:23 AM
RobbVII's Avatar
RobbVII
Default 2001 1500 Sport 4x4
I'm having shifting issues. I replaced the common pressure solenoid and now I can manually shift through the gears, but it won't shift it's self. And if I just shift it into drive, it takes off in second gear.
I'm getting these codes.
P0753 Shift Solenoid A electrical
P1764 Governor pressure sensor low
P1765 Transmission 12 voltage supply relay control circuit
Old Dec 3, 2018 | 12:00 PM
Are you getting 12 volts to the trans when the engine is running?
Did you replace the pressure sensor as well? Or just the solenoid?
Should be a 5 volt feed to the trans as well.
Old Dec 4, 2018 | 05:25 PM
RobbVII's Avatar
RobbVII
Yes. I replaced the sensor and solenoid. I will check voltage to trans next. Thanks
