Lower radiator support crossmember
Old Dec 5, 2018 | 10:34 AM
tharmon23's Avatar
tharmon23
Default Lower radiator support crossmember
hello i have a 1998 dodge ram 1500 i recently hit a telephone pole with and it pushed the passenger radiator support inward and i was curious if its possible to replace that entire support i already know how to take the radiator out and the top support but im unsure if i can replace the bottom portion it doesnt look like it bolts on it looks like its welded into place
Old Dec 5, 2018 | 04:24 PM
Mike Sal's Avatar
Mike Sal
If it isn't crushed too much you can probably pull it back out. log chains, a heavy come along, & a tree should do it. I've done this type of repair a few times. Saves trying to weld in a new header panel.
Mike Sal
Old Dec 7, 2018 | 01:09 PM
fj5gtx's Avatar
fj5gtx
The whole rad support bolts out. I picked up just the top cross member for $10 at the local pic-n-pull because the hood bumpers on mine were frozen with corrosion. Would be pretty easy to get it all of it.
