Airbag Wiring
Old Dec 14, 2018 | 01:24 PM
  #21
DerTruck's Avatar
DerTruck
Ah sorry, I misunderstood which wires had slipped out. Maybe this picture from an ebay auction helps:
Old Dec 14, 2018 | 02:05 PM
  #22
prairieschooner's Avatar
prairieschooner
Thanks but those wires are still in the connector it is the other side. I just need to know if the Dark Green goes to the White or Green or what the Black/Yellow connect to.
thanks
Old Dec 14, 2018 | 02:10 PM
  #23
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
thanks
Well sadly I'm no help. It's cold here and I don't want to take the risk of cracking my factory dash that isn't cracked yet.
Old Dec 14, 2018 | 02:15 PM
  #24
DerTruck's Avatar
DerTruck
thanks
You lost me. The picture shows the the wire colors at the airbag, the connector diagram I posted last night shows the wire colors at the connector coming from the airbag switch.
Old Dec 14, 2018 | 02:21 PM
  #25
prairieschooner
Don't blame you!
Old Dec 14, 2018 | 02:22 PM
  #26
prairieschooner
Your diagram pic left something to be desired & is for a 2001. Just wanted to clarify the connections
Old Dec 14, 2018 | 02:25 PM
  #27
DerTruck's Avatar
DerTruck
If you look at the connector from the pin side, with the latch pointing up, the black/yellow is on the left side and dark green/yellow is on the right. That's how the manual shows it.
Old Dec 14, 2018 | 02:43 PM
  #28
prairieschooner
Thanks! so if we now look at your picture showing the White on the Left side? & that would make the Green/Yellow to the White?
Old Dec 14, 2018 | 02:58 PM
  #29
DerTruck's Avatar
DerTruck
The picture shows the connector from the bottom, the slot is where it mounts to the airbag housing. So white is on the left side looking at the connector from the front. Note that it will connect to the right side on the other side. Are you missing any connector pieces ? Otherwise just reassemble the connector coming from the airbag switch.
Yes
