Airbag Wiring
Old Dec 11, 2018 | 11:07 AM
prairieschooner's Avatar
prairieschooner
Now looking pics of the harness in hopes of seeing that connector but so far no luck
Old Dec 11, 2018 | 11:25 AM
Check the connector pinouts in the service manual. Of course, that will likely reflect the wire colors shown in the diagram....... At what point do your wires change colors??
Old Dec 11, 2018 | 11:56 AM
prairieschooner
At the Connector. The Green & White wires are still in the connector just the Black/Yellow & Green/Yellow came out of the other side
Old Dec 11, 2018 | 07:27 PM
Well, according to theory, those are supposed to be 'twisted pair' wires. Diagram doesn't show any connectors between the module, and the airbag.... Can you post a pic?
Old Dec 12, 2018 | 10:03 AM
prairieschooner
The wires from the switch are twisted up to the connector leading to the airbag. The wires at the air bag are only a few inches long & go into the connector but are not "Twisted". You may be mistaken about "Twisted" wires the diagram ('98 & '99) shows "Twisted" wires to the Driver's Side but not at the Passenger's Side.
No pics working on getting it back together today,
thanks anyway
Old Dec 14, 2018 | 01:12 AM
DerTruck's Avatar
DerTruck
The service manual actually has the pinouts for all connectors. Here's the passenger airbag connector in the 2001 service manual.
Old Dec 14, 2018 | 10:09 AM
prairieschooner
Thanks! but any idea what color is 1 & what color 2 pins are? Or if White or Green is 1 or 2
Old Dec 14, 2018 | 11:55 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Neither of those colors are in the passenger side connector
Old Dec 14, 2018 | 12:37 PM
prairieschooner
Sorry but they are on my 1999
This is why I am asking questions
Old Dec 14, 2018 | 12:47 PM
The problem he is having is, the connector came off the airbag side of the wiring. He needs to know which wire is line one, and which is line two. Something that does not show up in the factory wiring diagrams.
I suspect that the only way he is going to get an answer, is if someone pulls out their connector, and has a look. And that's assuming there is some consistency of wire colors over the years......
