High beam lights always on!
Old Dec 12, 2018 | 12:05 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by john91
Moparfanatic21 which ground happened to be bad for you? I’m going to swap out the multi function switch tonight after work with a new one. I’m just as confused as you guys. I appreciate all the input!
I'll look when I get off work and let you know (around 3pm EST)
Old Dec 12, 2018 | 12:52 PM
john91's Avatar
john91
Ok perfect thank you! That would be awesome. I’m also an east coast guy!
Old Dec 12, 2018 | 07:37 PM
MoparFanatic21
Sorry I'm getting back to you so late pulled a double shift. There is a ground right next to my passenger side headlight.
Old Dec 14, 2018 | 03:15 AM
DerTruck's Avatar
DerTruck
As far as I can tell part of the confusion is that the internal connections of the beam select switch are not shown correctly. The way the diagram shows it the high beams would be on if the beam select is on high regardless of the headlight switch. The only time that is needed is for the "flash" function.
In any case the lights are turned on by connecting them to ground (they always have 12V present). The beam select and headlight switch carry the full current for two bulbs, either high or low beam depending on beam select. The ground for the lights is "Instrument Panel Right Center". The additional two high beams for the sport are switched via a relay because the wiring/switch weren't designed for twice the current.
Old Dec 15, 2018 | 06:50 PM
john91's Avatar
john91
So I changed the combination switch and nothing changed and issue. I’ve checked all the ground i can find. And everything seems solid. No broken wires or loose ground. I’m baffled
Old Dec 15, 2018 | 07:31 PM
MoparFanatic21
I can't remember if you tried it but what about the headlight switch?
Old Dec 15, 2018 | 11:20 PM
DerTruck's Avatar
DerTruck
Are you sure you have the correct light bulbs ? The Sport uses 9007 while the regular ones use 9004. The devious part is they have different pinouts so the wrong bulb can feed a small amount of voltage into the high beam circuit.
Old Dec 16, 2018 | 01:23 AM
Ramman18's Avatar
Ramman18
Fuse or fuse box hasn't been mentioned.
Old Dec 16, 2018 | 04:46 PM
john91's Avatar
john91
Yea replaced the headlight switch, I have 9007 bulbs on the outer for the lows, and 9004 for the inner highs like it calls for. Checked all fuses and relays. Everything checks out proper. I’m at a loss here
Old Dec 16, 2018 | 07:15 PM
Ramman18's Avatar
Ramman18
Then you have to start at the battery and chase every wire, connection, and switch down to the bulbs.
