Timing cover gasket repair cost?
Old Dec 15, 2018 | 10:32 AM
  #21
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by Aero540t
Thanks! Just moved to Portage, MI. I was never a dodge fan, but I used the truck a few times when my dad had it and I asked him to tell me before selling it and it worked out! It’s got heated leather seats and the works. Honestly I love it, just hard to spend money sometimes. I’ve done a bunch of PM on it in the last 1.5yrs
You are welcome! As RamMan said depending on your financial situation, you could try to temperary stop it.
Old Dec 15, 2018 | 07:39 PM
  #22
Aero540t's Avatar
Aero540t
I really need it reliable next week to help finish the move so I’d rather just get it done. It emptied the whole overflow tank in two trips totalling probably three miles so it was coming out pretty quick once warmed up
Old Dec 15, 2018 | 09:29 PM
  #23
Time to get it fixed. It also has the potential to leak INTO the engine, and mix with the oil. That'll smoke your motor awfully quick.
Old Dec 17, 2018 | 02:43 PM
  #24
Aero540t's Avatar
Aero540t
Well good news the mechanic was able to get a better look and he said it was coming from the rubber hose that connects to the top of the water pump(bypass hose it looks like). I remember it being in kind of rough shape and hard to get it connected when I was putting things back together. So it’s going to be much cheaper to get me back on the road.
Old Dec 17, 2018 | 04:41 PM
  #25
MoparFanatic21
If you have pliers and $16 you can do it yourself...
Old Dec 17, 2018 | 05:36 PM
  #26
Aero540t's Avatar
Aero540t
I’ll consider this one a stupid tax for not doing it while I had things apart. I’m in a time crunch and no tools but it’s done
Old Dec 17, 2018 | 05:58 PM
  #27
MoparFanatic21
Dang if stupid tax really existed I think I'd be homeless
Old Dec 17, 2018 | 08:23 PM
  #28
Aero540t's Avatar
Aero540t
haha isn’t that the truth!
Old Dec 18, 2018 | 12:01 PM
  #29
Ramman18's Avatar
Ramman18
Ha, good for you. Figured as much. At least you found an honest mechanic.
Old Jan 8, 2019 | 09:05 PM
  #30
1SaltyGreenBean's Avatar
1SaltyGreenBean
Think I would find out exactly where the leak is coming from first. It may be as simple as the bypass hose being a bit loose.
Glad I searched this. After doing my entire cooling system ( except heater core). On your advice, I did the timing set also. Two months later it started leaking anti freeze on the right side. Pulled it back down and replaced the water pump and timing chain cover gaskets. Now two months later or so it is now leaking on the left side. The only thing I haven't checked is the by-pass hose. That's what happens when you get old I guess. So if it's not the by-pass hose, which might be able to do this weekend, what would you recommend for a better gasket maybe Also some of the bolts as you know have what appears to be blue thread lock. Should these bolts have pipe dope or pipe tape. I'm using permatex blue gasket sealer for the water pump gasket. Please be the by-pass hose. The top radiater hose had to be tighted also. Thanks for any input!!
