97 ram 3500 2wd rear leafs
Old Dec 26, 2018 | 08:31 PM
bucketoval's Avatar
bucketoval
Default 97 ram 3500 2wd rear leafs
I have 3500 and I removed the flat bed and install regular bed and now the rear sit at least 3" higher than it should. I need a photo of a stock rear leaf pack setup installed. Thanks
Old Dec 27, 2018 | 01:56 PM
Does it sit 3" higher in back? So you have a rake toward the front? If so, that's normal. If the rear sits MUCH higher than the front, just pull a leaf or two......
Old Dec 27, 2018 | 02:19 PM
bucketoval's Avatar
bucketoval
Does the rear on a 2wd have a lift block? It still 3" higher than the normal rake
Old Dec 27, 2018 | 02:30 PM
It should, 2 or 4 wheel drive?
Old Dec 27, 2018 | 07:10 PM
bucketoval's Avatar
bucketoval
2 wd Cummins 5 speed
