Dash compatibility
Is my best course of action to get another dash/wire harness? Is there an explanation for this? Could it have been a transition year type of thing? Like in 99 they used some left over 98 wiring? I'm dreading this; removing a dash 4 times and installing one 2 times. It may have warmed up a bit but it is certainly not warm out. And the junkyard will be a mess after 18 inches of snow and now it's raining then turning back to snow. Sometimes I wonder why people live in the northeast!
We just looked at the wiring diagram from the FSM for 1998 and the pins match the replacement connector. There is no PK/RD wire. So I think moving pins around is out. We'll be heading back to the junkyard with the pin-out diagram to make sure we get the right one this time. I guess it is a transition year issue.
Let's say PK/RD wire is in pin #5 and controls dash lights.
Your factory plug may use GN in pin #8.
Just dig deeper
Is there an easy way to match the pin/wire color to the accessory that it runs? I had thought of going that route but I found it daunting to try and match the pin to the circuit. I felt like it would have to read through every dash related wiring diagram and map everything out. So, for example, how do I find out what the PK/RD wire runs which appears to be missing from the replacement connector?
I think what you're saying is that if I know RD/OR runs the high beams I would move it to pin 5 on the replacement. This would leave pin 35 empty on the replacement connector. And if, for example, pin 35 (which is supposed to be RD/PK on our truck) controls the right turn signal then find out what wire from the 98 FSM controls the right turn signal (maybe it's GN) and move it to pin 35. Am I understanding correctly? We would have to keep a note somewhere for future reference.
Also, how hard is it to get the pins out of the connector? Can I do it with some sort of combination of small screwdriver, pick and needle nose pliers? I see in the FSM there are special tools to get the pins out.
Thank you. I really appreciate the help on this.
Isn't there a chart that gives that info?
Otherwise, since it is a dash connector, look at the specific wiring diagram where that connector is. (probably on a couple.)
It used to be, that the entire vehicle wiring diagram was on one rather large page. (it would fold out a few times, and was even color coded) Wiring has gotten FAR to complicated for that though....
That's what I'm seeing in my FSM. However, looking at the pics in post 8 my connector is definitely not black.
