Bedliner
Old Jan 25, 2019 | 07:39 PM
Yep. Very glossy, and a smooth finish as well. However, it is NOT UV resistant, so, over time, if it is exposed to sunlight, it will oxidize, to an extent. Basically forms a white powder on the surface, and isn't quite so shiny.
Old Jan 25, 2019 | 09:40 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Don't they have a top coat like por15?
Old Jan 25, 2019 | 09:56 PM
I believe you can paint over it with anything you like. Might need to scuff the surface a bit first though. (yeah, good luck with that....... )
Old Jan 25, 2019 | 10:07 PM
fj5gtx's Avatar
fj5gtx
I think manufacturer suggests you can prime/paint over it when its tacky...
Old Jan 25, 2019 | 10:54 PM
MoparFanatic21
See POR15 has that tough base coat and then they give you a top cost to make it UV resistant
