Questions about the sport model 2001 ram 1500
Old Dec 10, 2005 | 08:23 PM
Needforspeed318's Avatar
Needforspeed318
Default Questions about the sport model 2001 ram 1500
Hey everyone. New to Dodge Forum here. Was actually wondering why most of the sport model trucks that were produced in 2000 and newer mostly came with the posi-trac rear and the 5.9l engine. Mine is a 2001, and it has the open rear.. and also the 5.2. Was also wondering the best way to get a posi rear.. is it better to go aftermarket with a detroit and have the rear rebuilt or buy a factory used one and rebuild it from there?
Thanks everyone,
Raymond
Old Dec 10, 2005 | 08:37 PM
Socha_62's Avatar
Socha_62
Default RE: Questions about the sport model 2001 ram 1500
You can get the posi units for like 250 I think. Try. www.drivetriandepot.com or http://www.valleytruckparts.com/
I would just get an aftermarket one. First link I put is a good one I think.
Old Dec 10, 2005 | 10:01 PM
MGDMike's Avatar
MGDMike
The first link is not working for me but the second is doing fine...
Old Dec 10, 2005 | 10:08 PM
Socha_62's Avatar
Socha_62
I spelled it wrong hahaha here it is!
http://www.drivetraindepot.com/
Old Dec 11, 2005 | 11:57 PM
shott8283's Avatar
shott8283
9 outa 10 times they were special order from the fact. . mainly with what package... offraod sport..i think gamme the lsd rear with 4.10 gears (posi) and my 360...anyone confirm?
Old Dec 12, 2005 | 12:51 AM
1500sport's Avatar
1500sport
ORIGINAL: shott8283
Once again here is a link that will answer many questions:
http://dodgeram.info/2001/models/1500.html
Off-Road Group
--- Includes the Heavy-Duty Service Group, limited-slip rear differential, unique suspension, special skid plates, tow hooks, 4.10 axle ratio, fog lamps, special graphics, off-road tires, and 17" cast aluminum wheels
An anti-spin rear differential is optional on the other models which as far as I know is the same as the limited slip diff. described in the off-road package. Don't know why they call them different though.
Axles --- Anti-spin rear differential (specific ratios only): it doesn't list which ratios though[:@]
Old Dec 12, 2005 | 01:15 AM
shott8283's Avatar
shott8283
and like i siad...a lot are special orderded... like the sport group describes as a aux tranny cooler like the heavy duty group. also re-described in the offraod grouping too.. i ahve the offraod sport package .. and no aux tranny cooler nor sighns of one ever being on there... if you look carefully... the re-ocurring "S" and "O" means STANDARD or OPTION... meaning you can have a special grouping of options but half of them are OPTIONAL on certain models... with the grouping options on that page...2 peopl could have identical looking trucks but be completley different.. a buildsheet is more usefull then that page..
Old Dec 12, 2005 | 01:16 AM
Socha_62's Avatar
Socha_62
I have 3.92's and I have LSD. I wonder if it was 3.92 and 4.10's only?
Old Dec 12, 2005 | 02:01 AM
Needforspeed318
Socha.. i have looked at the rear end options on a hollander parts system and the 3.92 were an option then the 3.55 were an option also. Only thing being the 3.55 came with locking or non locking.. was just wondering about this all because, everyone i know who has a sport 2wd has the posi rear with the 360...
Old Dec 12, 2005 | 02:24 AM
Socha_62's Avatar
Socha_62
Hmm so it is doable. I guess it just depends on what you want to do with your truck. If your gonne jack it up and get bigger tires in the future you'll need higher gears. So it'd be cheaper to ride it all out untill you get the other gears and get either posi or a locker all at once.
But if your gonna keep the same gears just keep on looking for a posi unit, or locker Aftermarket would be alot better and probably cheaper. I heard somewhere that the LSD units that came from the factory actually have a tendancy to crap out after a while [&:] Called the dealer up here once and they said they keep 3 IN STOCK at all times. They have to put them in trucks that work in the oil fields all day on a regular basis.
I think mine might be on its way out too. When the rear end is lifted up and you spin one tire the other spins the opposite direction, not the same. But on gravel or snow and I floor it both spin.
