EGR issues
Old Feb 4, 2019 | 02:43 PM
Tompaulbar's Avatar
Tompaulbar
Default EGR issues
My 01 ram 1500 5.2l when I put it in gear as soon as any gas is given it dies. No sputtering on idle nothing seems wrong until I put in gear.... EGR?
Old Feb 4, 2019 | 02:55 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
You don't have an EGR valve. Did you ever clean the throttle body?
Old Feb 4, 2019 | 03:11 PM
Tompaulbar's Avatar
Tompaulbar
If I don't have an EGR what is the component on the driver side under the battery? A vacuum line and what looks like a throttle cable are connected and it has a diaphragm.. I've cleaned the throttle body half heartedly.
Old Feb 4, 2019 | 03:40 PM
Cruise control.
Old Feb 4, 2019 | 04:15 PM
MoparFanatic21
Do you have a scanner they can see live data?
Old Feb 4, 2019 | 05:30 PM
Torxhead's Avatar
Torxhead
A guess would be iac valve needs cleaning.
Old Feb 4, 2019 | 06:25 PM
Tompaulbar's Avatar
Tompaulbar
I don't have a scanner but here is a picture
Old Feb 4, 2019 | 06:42 PM
Tompaulbar's Avatar
Tompaulbar
The whole issue is that when I put it in any gear besides park and neutral it dies. It idled like a champ
Old Feb 4, 2019 | 06:54 PM
Does it bog down and die or just shut off like you turned the ignition off?
Old Feb 4, 2019 | 07:54 PM
Tompaulbar's Avatar
Tompaulbar
It bogs down I can't go 5ft without it dying.
