Can u tell me what's missing please
Old Feb 11, 2019 | 04:03 PM
Behindblueyes's Avatar
Behindblueyes
Default Can u tell me what's missing please
Is this green cable with black top supposed to be attached to anything on drivers side
This is it
My son went mudding afterward the air from the vents only went to defrost I've dealt with this before so I was checking the lines and noticed this hole it sucks when truck is running is there a piece missing thanks Also noticed this green cable with black at the end hanging is this supposed to be like that. Thank you 1998 1500 5.9 4x4
Old Feb 11, 2019 | 06:30 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
This is it
The green line is the vent for the transfer case so yes. That other piece should connect to the line for the vents
Old Feb 12, 2019 | 01:02 PM
CJSuhr's Avatar
CJSuhr
The green is how it should be, but I actually believe the second black y-connector is for the cruise controller servo. If you follow that black line back further towards the firewall is where you'll find the vent vacuum line next to the AC Lines that run into the firewall. Check the cruise vacuum cable.
Old Feb 13, 2019 | 06:19 PM
aresf11's Avatar
aresf11
You just need to get vacuum back to your controls somehow, so if you can't find that specific line, just grab vacuum from somewhere else (tap into brake booster?) and your controls will work again.
Old Feb 13, 2019 | 06:35 PM
Moparite's Avatar
Moparite
The vac tap is the one on the intake(second pic) The other line should go to the cruise servo.
