Transfer case bushings
Old Feb 18, 2019 | 08:59 PM
V10ram2500's Avatar
V10ram2500
Default Transfer case bushings
Hello everybody I was wondering if anyone knew where to get transfer case shift linkage bushing for a 1994 ram 2500 v10 that aren't 15.00 a peice. The only place I have found them are on torque king. The ones on Amazon and eBay are the black ones . Are they as good as the original green ones or should I just buy a new linkage for all together.
Old Feb 18, 2019 | 09:10 PM
If the cheap ones are correct, just get a couple sets. If you go thru them quickly, spring for the expensive ones, if not.... run 'em.
Old Feb 19, 2019 | 02:52 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
There is a thread in the 3rd gen section on how to build your own linkage without bushings. I'm still on the factory bushings but when they go I'll build mine custom.
Old Nov 30, 2019 | 11:03 AM
marcpilot1's Avatar
marcpilot1
On that 3rd gen thread where it shows how to build it without the bushings, using the turnbuckle and washers, etc, will that also work for our 2nd gen rams? Mine is 98 Laramie with an NP231 in it. Thanks for any help!
Old Nov 30, 2019 | 02:27 PM
MoparFanatic21
It will
