Dash and tail lights out
Old Feb 21, 2019 | 08:15 AM
drewbaker91's Avatar
drewbaker91
Default Dash and tail lights out
I have a 1997 Ram 3500 with the Cummins. I recently pulled the dash out to replace the cracked dash and went ahead and changed the heater core and evaporator while i was at it. Before this project my lights use to shut off after about 30 minutes. The truck has done this for some time and last time i just replaced the headlight switch and harness. So while we had the dash out I changed the headlight switch again. At first everything seemed to be working. But once i turned the dome light on the dash and tail lights quit working. I can get them to work if i hold the light switch in between the off and running light detent on the switch. once you let the switch fall into the detent of running lights or headlights they go off. I have seen many threads about this but one has seemed to figure this out. any help would be greatly appreciated.
Old Feb 21, 2019 | 08:19 AM
There is a thread by moparfanatic on this exact problem. Look up his thread for the fix.
Old Feb 21, 2019 | 09:14 AM
drewbaker91
Thank you so much. Took me a bit to find it but im hoping that its the same issue causing my problem.
Old Feb 21, 2019 | 02:18 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Damn I'm famous now
Old Feb 21, 2019 | 06:58 PM
Damn I'm famous now
Indeed you are.
Old Feb 21, 2019 | 07:24 PM
MoparFanatic21
Indeed you are.
What can I say if a problem can happen it'll usually happen to me
Old Feb 21, 2019 | 07:27 PM
I am all too familiar with that........
Old Feb 21, 2019 | 09:53 PM
MoparFanatic21
My methods of finding the problem are.... What would you say...unorthodox
