Alternator question
Old Mar 5, 2019 | 11:28 PM
96ram150's Avatar
96ram150
Default Alternator question
So my 96 ram 1500 5.9 has the 117 amp alt. I want to put a new one on it but only options I have is 70-79, 90-99 and 120-129 neither specify the 117 amp. Witch one would I need?
Old Mar 5, 2019 | 11:54 PM
Ramman18's Avatar
Ramman18
Put the big one on.
Old Mar 6, 2019 | 09:03 AM
96ram150's Avatar
96ram150
Originally Posted by Ramman18
Put the big one on.
Would I need to change alt fuse at fuse box?
Old Mar 6, 2019 | 09:42 AM
Ramman18's Avatar
Ramman18
I really don't know but I would like to think not. If stock was 117, then get as close to that as you can without going under which is the 120. I wouldn't worry about a fuse.
Old Mar 10, 2019 | 03:25 PM
TfG DeViN's Avatar
TfG DeViN
Default 96ram150
Yes,if your fuse isn't pushing the same exact amps as your alt than it will eventually cost you an alternator, Make sure your alt fuse is either pushing same amount or higher amps,if the amps r higher than wat your alt pushes its better for it,so if I was you I'd go with a 120amp or the 129
Old Mar 11, 2019 | 09:31 AM
Why would you install a fuse rated higher than the output of your alternator? Seems like a good way to smoke an alternator to me.
