Where can i find a transmission pump for this 94 ram
Ebay has a bunch. They also have complete transmissions for sale. I would highly recommend replacing the whole thing. There is a REASON your pump died, and my guess is, that reason will still be present after you replace the pump.....
Is it confirmed that pump is gone bye bye? Like pressure measured from the test ports? Quick way to see if the pump actually works, is to check oil level engine off, then start the engine and check the oil shifter in neutral. If the pump works, oil level goes down while engine is running.
There are bunch of reasons why you don't have gears in any direction, though pump is one, but more likely there's a burned clutch pack.
Ok i found a 95 tranny but its a manuel the guy has all the pedals,clutch reservoir, and the flywheel which come off of a 95 5.9 manuel. My question now is thats all the parts that i need to convert my 94 ram 1500 auto to a manuel 5 speed?
