Custom tuning ?
Old Mar 19, 2019 | 10:14 PM
dodgeit1999's Avatar
dodgeit1999
until I screw something up
lol its not bad, just take baby steps.. one of the down falls is our trucks dont have knock sensors, so ignition timing has to be crept up easy and keep an eye out for detonation. With tuning you can remove the torque limiters. Even on a bone stock engine while running 91 or 93 octane, with proper ignition advance its a night and day difference.
Old Mar 19, 2019 | 11:43 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I'm not good with tuning and no classes near me so I'll leave it to a company, that's a downside lol.
Old Mar 20, 2019 | 08:18 AM
ZEN357's Avatar
ZEN357
Right now I own a 2006 300C as my daily driver. What kind of tuner do I need for that?
I know with my 2016 Challenger I was going to go with HP tuner's and a new programmable PCM.
Old Mar 21, 2019 | 01:12 AM
44dakota's Avatar
44dakota
I just bought the syked SET tuning suite with handheld for my 5.9 dakota, im looking forward to modifying my superchips tune, i havent down loaded the file yet, but, will this weekend , basically i want to start out by eliminating all torque management, then set the timing curve were it really should be..would like to get it around 34 total advance at WOT...when i do a cam swap, probably marty fletchers utp500, ill need to do some fuel adjustments as well, especially at idle, will be some learning involved ,but,i know what i want to get out of it already...possible turbo in the future if i get enough knowledge of the SET...
Old Mar 21, 2019 | 08:07 AM
ZEN357's Avatar
ZEN357
Was looking at this one for my 2006 300C Heritage model.....
https://www.diablosport.com/shop/pre...sler-cars.html
Old Mar 22, 2019 | 06:51 PM
dodgeit1999
I can help you out with learning the program, SCT and SET are set up similar. I wouldnt do 34* right off the bat. Your going want to start off at a max of 28* start off with 180* thermostat and either NGK bkr6e or autolite 3923 spark plugs. If you have any oil induction I.E leaking valve stem seals (like i do) then your timing will be limited on how far you can go up. You can work on the cruising cells too so you can get better MPG as you will be creating more cylinder pressure and not have to be in the throttle as much.
Old Mar 22, 2019 | 06:53 PM
dodgeit1999
its not avalible for custom tuning so its loaded with generic tunes. If you want to do custom tuning or have someone custom tune you will need to choose a different hand held unit
Old Mar 25, 2019 | 07:33 AM
ZEN357's Avatar
ZEN357
Any Recommendations?
