New Member
Old May 17, 2019 | 09:05 PM
cegulley's Avatar
cegulley
Again, your knowledge amazes me. I had not even mentioned the misfire situation I have been having since rebuilding the engine. I was thinking it was a ground wire issue and would get to it soon enough.
After researching the misfire and stutter at 45 mph I ran across the TSB which discusses routing of spark plug wires. So I went and looked....Yep they were all crossed up and touching each other. I rerouted the even numbers (because most misfires were No. 8) and started her up. NO MISFIRES at idle.
It got dark so I will have to wait and test drive tomorrow.
Another issue though. As I was rerouting the spark plug wires I had to move and manhandle some of the vacuum lines. Now I have a green vacuum line going down the back side of the engine (maybe to the transmission) but cant seem to find where it connects up top. Any suggestions?
Clark
Old May 18, 2019 | 02:18 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Clark
Green Vacuum Hose is a vent for the transfer case. Should have a plastic circle in the end if it
